Why the new Mythic pool feels off
The big change is pretty simple: more Unique items can now roll into Mythic quality, but that wider pool makes target-farming feel messy. If you're trying to finish one build, you don't want "a Mythic" so much as the right Mythic, and that gap matters a lot. Players keep saying the same thing in different ways: the drop can be exciting, sure, but the odds of it being useful are rough, and the old sense of steady progress is mostly gone.
- Farm more, but expect fewer useful hits.
Check every drop against your build, not hype.
Assume the item pool may fight you the whole way.
Crafting got weird, and people noticed fast
The Horadric Cube side of this is where a lot of the anger gets baked in. You put in a Unique, pick the upgrade path, and you don't always get a stronger version of that same thing. Sometimes you get a totally different Mythic, which means the process feels less like crafting and more like handing over a decent item and hoping the game feels kind. If you're running a build with narrow gear needs, that randomness hits even harder. Nobody likes seeing a good piece disappear into a slot machine.
- Strength-based builds hate random swaps the most.
Builds with one key item feel every bad roll.
Fast farming helps, but it does not fix bad odds.
Reality check: if a system deletes your good gear and spits out something random, players will call it a gamble, not an upgrade.
Why long farming sessions make it worse
That's also why the community examples have stuck around. A player can run bosses for hours, see dozens of Mythic drops, and still come out with nothing that fits. It's not just the number of drops. It's the feeling that time spent and character progress have stopped matching up. When the season asks for repeat runs, repeat mats, and repeat patience, the whole thing starts to feel a bit cold. People are not asking for free power. They just want a path that feels fair enough to chase.
- Track your target items before you burn boss mats.
Stop assuming any Mythic equals a real upgrade.
Keep spare gear ready, because good drops can miss hard.
The real fear is losing control
What players seem to miss most is control. Earlier systems in Diablo 4 already had some RNG, but there were more ways to shape an outcome. Tempering, enchanting, masterworking, all that stuff at least gave the sense that you could steer the build a little. Season 14 pushes back the other way. You can grind, you can prep, you can do everything "right," and still end up with a Mythic that belongs in another stash tab. That's the part that gets under people's skin. It's not only rare. It's unpredictable in a way that makes planning feel pointless.
- Save resources for the exact build you're playing.
Use spare legendaries before risking a prized Unique.
Be ready to pivot if the drop pool keeps trolling you.
At this point, most people seem less interested in drama and more interested in a fix, or at least some tuning. If Blizzard wants Season 14 to land better, the obvious pressure points are drop rates, cube outcomes, and how narrow Mythic targeting really is. Players don't need every chase item handed out. They just want the road there to feel like an actual road. Right now, for a lot of folks, buy Diablo 4 Items sounds calmer than gambling another night away on the same broken loop.
